Pt asw 20
Pt asw 20
Started to modify my pat teakle asw 20 . Wings have been changed to 4 piece so should fit in car with wife. Now cutting nose off to fit motor . Turnage 50 size 16 x10 propeller
Re: Pt asw 20
Good luck with the conversion Roo.
I’ve thought about doing the same to mine but wouldn’t want to add any more weight given the age (30 years+) and construction of the wings (glassed, but crumbly Copydex glued veneer) and the single 15mm Graupner steel strip joiner. I still love it though!
Re: Pt asw 20
If it's 30 years old, that's probably a 14mm joiner, Rog... (CW: Chairman, Pedants R Us)
Re: Pt asw 20
Aye, but everything’s bigger and better in Yorkshirechris williams wrote: ↑07 Dec 2023, 15:18 If it's 30 years old, that's probably a 14mm joiner, Rog... (CW: Chairman, Pedants R Us)
Re: Pt asw 20
Hi Roger mine is blue foam wing with carbon spars and 16mm round joiner.
Re: Pt asw 20
Rhinoplasty, AAAAAAAAAAAAAAAAHhhhhhhhhhhhhhhhhhhhhhhhhhhhh
