Let Model DG1000S 1-3.75 scale, 5.33m w/s.
Place your Sales adverts here.
MDev
Post by MDev »
Let Model 1-3.75 scale DG1000S, 5.33m wingspan, complete with two sets of Let wingtips, one set of carbon raised wingtips with outer ailerons and one set of plain tips for aerobatic flying. Carbon joiners. Multiplex type wing securing. Let Model built interior of cockpit with instruments, dials, seating, controls and harnesses etc. Ailerons, outer ailerons, flaps, air brakes, landing wheel on retract, rudder, elevator and tow release. Small crease on mould join under boom. 2 X 6700mah lipo Overlander battery packs with Jeti Max Bec supplying two rx from two batteries. Multiplex magnetic switch. Tailored Let cockpit cover. The servos are mainly Hitec digital except the outer ailerons.
The elevator and rudder can be quickly released for transportation, the fuse does fit inside a 2m 25cms roofbox (just!) (box not included). This model is the all glass version and is a superb flyer that seems to fly forever. It is based on a DG1000S that flies out of Lasham in Hampshire and has all the same scale graphics.
£650 07762595788.
I’ll add smaller photos over the next few hours.
SOLD, SOLD, SOLD
