Tow Rag
Posted: 16 Oct 2015, 10:27
by FrankS
Well after our Ampley had an argument with the sheep feeding trough, we've decide to go a bit left field on building a replacement, a Keith Humber Towrag, plans originally published in 1987 (and I've had them almost as long), original was for a 90 Webra T4 fourstoke so our electric conversion generating almost 2KW shouldn't be underpowered.
Re: Tow Rag
Posted: 17 Oct 2015, 05:50
by Pat Marsden
Ok, who moved the feeding trough
Ampleys are tough but there is a limit Frank
Re: Tow Rag
Posted: 17 Oct 2015, 17:02
by FrankS
Pat Marsden wrote:Ok, who moved the feeding trough
I've still kept the fuselage which is repairable and might do a built up wing for it, it was a bit porky.
Re: Tow Rag
Posted: 18 Oct 2015, 07:30
by john greenfield
Plans for a built up Ampley wing are available as a free download from the Ghost Squadron website if you want to rebuild at sometime.
http://www.ghostsquadron.co.uk/greenley ... _page.html
Re: Tow Rag
Posted: 15 Dec 2015, 16:55
by FrankS
Tow Rag coming along, no big rush as long as it's ready for spring.
Re: Tow Rag
Posted: 28 Jan 2016, 21:30
by FrankS
Some progress
Re: Tow Rag
Posted: 12 Feb 2016, 19:53
by FrankS
All we need to do now is fly it, but maybe our Ampley wasn't too porky this weighs the same 6.5kg with an 8s 5000 mah battery.
Re: Tow Rag
Posted: 21 Mar 2016, 09:51
by FrankS
Just thought I'd wrap this thread up with a couple of photos from the flight test, on the current set up with an 18 x 10 APC prop, the motor pulls just under 50 amps on the 8s battery, around 1500 watts, performance is sprightly and it towed up Rogers Seagull 3m Pilatus with ease. Very smooth flier and as we have a 75amp ESC (limited to 8s though) we've got options to increase the power. The Towrag is a delight to fly though, looks a bit unusual
but flies brilliantly and lands at walking pace, just what we need for our club field which is a bit tight.
Re: Tow Rag
Posted: 22 Mar 2016, 18:35
by C.olson
Well done it looks really smart and good to see something different doing towing duties may she reward you all summer long
