1/3rd scale ka8b -island models**
Posted: 29 Oct 2015, 00:48
by mick a
just started building 1/3 scale ka8b from island models
excellent kit and a joy to put together
please feel free with any comments to heelp on way
Re: 1/3rd scale ka8b -island models
Posted: 29 Oct 2015, 00:50
by mick a
and a couple more
its a big -un
Posted: 29 Oct 2015, 11:49
by Jason Griffiths
Hello Phillip.
Had my eye on 1 of these kits for a while, i will watch your build with a eye out as well, keep building
Posted: 29 Oct 2015, 17:07
by mick a
this is my second one
i did the 1/3 rd scale ka3
excellent kit flies like a dream
Posted: 29 Oct 2015, 17:09
by mick a
Posted: 29 Oct 2015, 18:36
by Jason Griffiths
Very nice
Posted: 29 Oct 2015, 20:43
by mick a
thanks
its a good flyer and a bit different
Posted: 29 Oct 2015, 20:55
by mick a
just to see the size of fuse
Posted: 30 Oct 2015, 15:32
by Jason Griffiths
Again Mick very nice
Posted: 25 Nov 2015, 21:04
by mick a
just a couple more on the ka8b build
Posted: 25 Nov 2015, 21:06
by mick a
just to show size , thats a full size drill in cockpit
Posted: 04 Dec 2015, 20:52
by mick a
bit more progress slowly but surely
Posted: 05 Dec 2015, 00:07
by Jus Gordon
It's looking good, coming along nicely.
Posted: 05 Dec 2015, 12:09
by Jason Griffiths
Yep looking good
Posted: 16 Dec 2015, 15:02
by mick a
getting there slowly but surley
just detailing of cockpit area and canopy to fit to frame and fuse done
then just wings
enjoying the build loads
Posted: 17 Dec 2015, 21:04
by mick a
Hi Rudi,
Great web site of yours. I like the ka8b build.
Like yourself I built ka3 first, see earlier post on this thread for video of maiden
Have you finished both and flown ?
The ka3 flies like a dream.
Did you have any difficulties with the wings on ka8b ?
Posted: 20 Dec 2015, 13:10
by Jason Griffiths
Some very nice work going on here, so tempting to get 1 myself
Posted: 21 Dec 2015, 14:25
by mick a
here are some pics of the canopy , out of 4 mm brass tube , great to work with
yes jason you should get , excellent kits
rudi ... no probs with c of g in ka3 came out about 7.5 kilos
and on the wing joiner tube ,
Posted: 01 Jan 2016, 22:15
by mick a
hi selleri
thanks for that , if it flies as well as ka3 , will be very pleased
just finished the hinges and catch , and started to do cockpit
wings next week
i have a building board which is not long enough- i was going to build from root then sheet root area then shit along it will be about 30 cm , i think this should work out ok
any thoughts ???
Posted: 01 Jan 2016, 22:16
by mick a
Posted: 06 Jan 2016, 07:42
by mick a
a new lock system , this one a bit more scale
be ok when cleaned up , spent way to much time on this one bit
on to more progress now
Posted: 13 Jan 2016, 07:59
by mick a
altered the canopy catch , now looks a bit more scale like
just have to make the sliding window now , and then detail cockpit
Posted: 13 Jan 2016, 08:02
by mick a
just started on the wings last night , all going together nicely
as you can see board is not long enough , so have built from root to as far as i can then slide along and keep flat , it seems to be straight
Posted: 13 Jan 2016, 08:03
by mick a
Posted: 14 Jan 2016, 13:38
by Jason Griffiths
Still looking good Mick
Just wondering if anyone else is interested in buying 1 of these kits ?
Posted: 14 Jan 2016, 17:45
by mick a
have a look on there website
island models
they have a few good ones
Posted: 19 Jan 2016, 16:54
by Jason Griffiths
Mick - Yes i have had a good look on Fred's website and yes there is some nice kits on there, i would like to build another scale glider at 1:3 scale
Posted: 23 Jan 2016, 21:54
by mick a
a bit more work done
one wing semi complete , just top sheeting and brakes to go
please with the fit
its a bigun !!
Posted: 24 Jan 2016, 15:45
by Jason Griffiths
Looking good Mick
As i have said before is their any one else interested in this kit/model ?
Posted: 24 Jan 2016, 22:59
by mick a
hi jason
doesnt seem to be , he seems to do ok over on mainland europe
i sort of found by accident , and not looked back
thinking about covering , last one used solartex but would like to try devcon if anyone has used and even better where can i get in uk
Posted: 25 Jan 2016, 07:33
by john greenfield
Mick
Devcon is an epoxy and probably not that good for covering open structure models. Did you mean Diatex ? If so it is sold by Skysport Aviation and the grade you need is Diatex 1000. it comes on a roll 60" wide. Skysport also sell the low taut dope you will need to fill the weave. They also sell a covering cement (Glue) but it I find it too thick and a pain to use so I just use Balsaloc.
Posted: 25 Jan 2016, 19:21
by mick a
thanks john
found sky craft is that the one ? , but only have 2 yrd in stock
i normally use solartex , is there much advantage with diatex ?
also can i use a dope on solartex to fill weave or just use thin paint or matt clear as i have done before ?
thanks for your help
mick
Posted: 26 Jan 2016, 09:41
by john greenfield
Mick
Sky Craft is the place, they are in Spalding, Lincs
Diatex is stronger than Solartex and the bond to the underlying structure is better when properly applied and it is more temperature stable so adds strength to the structure better than Solartex. Being 60" wide also makes covering bigger models easier without having to worry about joints. Properly applied I do not think it is any heavier than Solartex that has been sealed ...but .. although it takes no longer to apply that Solartex it does then need several coats of dope to seal it before applying any finish paints.
Sealing Solartex can be done with dope or paint but I am sure there are others who can advise the best products to do this as there is some fantastically well finished Solartex covered models within our community.
Posted: 26 Jan 2016, 20:49
by mick a
thanks john
great help , think will try it out on this one , as its 5 meter it will take a bit of covering
and will use balsa lock as you said
i presume its heat shrink the same ?
Posted: 29 Jan 2016, 17:23
by Jason Griffiths
Evening Mick - What size wing joining tube did you use 19/20mm ?
Posted: 29 Jan 2016, 22:03
by mick a
hi jason
its 24 mm with 20 mm rod for main and 12 mm with 10 mm rod for incedence pin
you thinking of going for one ?
Posted: 30 Jan 2016, 08:23
by john greenfield
mick a wrote:thanks john
Mick
Diatex shrinks in direct proportion to the amount of heat so start at a low temperature (90 to 100deg) and go over the whole surface. Only turn the heat up a little at a time (10deg) if you need more shrinkage. It will take a very high heat but if you start high you will loose all control over the shrinkage.
Under no circumstances use a heat gun as this will ruin the fabric.
Don't forget to dope all round the edges first to seal them before shrinking and work from the middle out to the edges to avoid reactivating the balsaloc and releasing the covering.
Posted: 30 Jan 2016, 14:20
by Jason Griffiths
mick a wrote:hi jason
I am looking in to a kit
Posted: 30 Jan 2016, 14:42
by mick a
i would say go for it
they are all nice , the ka3 1/3 rd is great kit
and the granau baby looks good with all ply covering
Posted: 11 Feb 2016, 22:36
by mick a
hi gents
just finished cockpit detailing , pleased with results
thanks for all your help
Posted: 21 Feb 2016, 11:56
by mick a
hi jason
have sent pm to you but seems to be stuck in outbox
Posted: 21 Feb 2016, 12:06
Mick,
It's not stuck in the Outbox, it sits there until the recipient collects it.
Posted: 21 Feb 2016, 22:38
by mick a
ok thanks robbie ,
here are a pic of first put together , at our winter projects night
Posted: 21 Aug 2016, 00:29
by mick a
finally finished framework
just need to cover now , solartex seems to be easiest to get
Posted: 07 Sep 2016, 09:10
by mick a
just starting to cover
and came up with this colour scheme , a copy of hungarian glider , from the club im in over there
Posted: 30 Oct 2016, 07:54
by mick a
finally
all finished k8 , just waiting for good wind and day off now
Posted: 30 Oct 2016, 14:54
by Geoff Pearce
That looks nice,, I hope it flys as good as my 1/3rd scale
Best of luck on your maiden.
Geoff
Posted: 02 Nov 2016, 14:40
by Jason Griffiths
Mick - Looks nice, when's the big day
Posted: 02 Nov 2016, 20:38
by mick a
hi thanks for kind words
just need to get a good wind at local site, thurnham (detling ) in kent and day off to coincide !!!!
Posted: 01 Jul 2021, 08:11
by waldopepper
Hello Mick,
did she fly then ? I am considering buying the kit for next building season, would you recommend it for an intermidiately skilled modeller ?
Regards from Austria,
Walter
Posted: 01 Jul 2021, 09:16
waldopepper wrote: ↑01 Jul 2021, 08:11
Hello Mick,
Walter
You could do worse than to try this one:
https://lasercutsailplanes.co.uk/produc ... les-smits/
Posted: 01 Jul 2021, 10:11
by Max Wright
She's a cracker, Mick.
Beautifully finished.
