30% Wilga Build
Posted: 29 Jan 2016, 07:40
by Elliot Howells
Hello all,
just started my Bondy Wiggler, thought I'd share some build pics as I go, hope that's of interest.
Will post them on this thread a little later on today when I get them off my phone, only hit one small glitch so far, a really enjoyable well thought out kit.
Ell.
Re: 30% Wilga Build
Posted: 31 Jan 2016, 20:38
by Darren M
Hi Elliot
I'm looking forward to your build thread. I had all the intentions of doing one but unfortunately I'm not so good at keeping up to date with the photos.
I've reached the priming stage with mine I just need to layup the cowling and it can all come together.
Darren
Re: 30% Wilga Build
Posted: 31 Jan 2016, 22:17
by Elliot Howells
Hi Darren, looking good!
I see you have an addiction ;)
Just waiting for my wood delivery from SLEC before I can make serious inroads, I don't take as many photos as I ought, that's why I started this thread, thought it might encourage me. Just discovering the small errors I've made so far, aligning the main cnc cut longerons has proved troublesome and now I'm finding where the errors lie. Also had to 'unglue' the tailplanb seat so that I could glue the fin post in...
One has to remember that it's all just a way of holding the wings, tail and engine in place really, if you can make it look like a real one, then so much the better.
Ell.
Re: 30% Wilga Build
Posted: 01 Feb 2016, 00:13
by Tom Pack
Very nice Elliot.......I have a 40% one of these sitting in the corner just waiting for me to get to it.......
Re: 30% Wilga Build
Posted: 01 Feb 2016, 07:48
by Elliot Howells
40%?
Blimey Tom, I wouldn't be able to fit that in my workshop.
Is that the bond design scaled up?
Ell.
Re: 30% Wilga Build
Posted: 01 Feb 2016, 16:17
by C.olson
Coming together really nice Elliot , iv got bondy's 1/4 scale z-37 cmelak plan and I'll be building that next year but I'm being sensible and building a greenly 1st and get used to towing with a non scale tug,,,,,I'm assuming you had the parts Cnc cut for the wilga? What size engines does She take ? Keep the pics coming .
Chris.
Re: 30% Wilga Build
Posted: 01 Feb 2016, 17:56
by Elliot Howells
Hi Fellas,
this is the bigger kit, I think the cowl you produce is for the 25% Keith?
SLEC laser cut and cnc routed this short kit, it really is superb.
More to follow as soon as the wood pack arrives this week, oh, the engine? A DLE 170 - totally over the top, but you cannae beat extra horsies when towing.
Ell.
Re: 30% Wilga Build
Posted: 01 Feb 2016, 19:56
by C.olson
Hiya
170 cc should do it !!!! I don't happen to have one of those laying around though so perhaps Id better stick with the z37 cmelak ,
Although I do have some 1/4 scale wilga plans about here somewhere!! It's Handy to know I can still get a fg cowl sometime though.
Bondy's plans are very well drawn I'll be watching your build closely (committed wilga fan) cheers chaps.
Re: 30% Wilga Build
Posted: 01 Feb 2016, 20:26
by Darren M
Hi Elliot
Looks great keep the photo's coming.
The second Wilga in the photo belongs to Ray Watts it's in for a little cosmetic Job.
I'm still unsure on the power plant for mine I would love to fit a 170 if it'll fit.
Darren
Re: 30% Wilga Build
Posted: 02 Feb 2016, 01:09
by Tom Pack
Elliot Howells wrote:40%?
Ell.
Yes it is.....and it is BIG!
Re: 30% Wilga Build
Posted: 02 Feb 2016, 17:26
by Elliot Howells
Darren, is yours the 30% ?
The DLE111cc was a perfect match for the 1/4 scale, tow pretty much anything with ease.
More progress today but still waiting on my sheet and strip :(
Ell.
Re: 30% Wilga Build
Posted: 02 Feb 2016, 19:38
by Darren M
Elliot
Mine is the 30% Same as yours.
Darren.
Re: 30% Wilga Build
Posted: 02 Feb 2016, 20:27
by Elliot Howells
The only issue then, will probably be the prop size.
I'm going to have to use a 3 blader I think, 32" is a LOT of prop.
:D :D
Re: 30% Wilga Build
Posted: 14 Feb 2016, 20:51
by Darren M
Hi Elliott
I moved a another step closer today I fitted the wilga together as one for the first time.
So far so good.
Darren
Re: 30% Wilga Build
Posted: 15 Feb 2016, 18:07
by Ray Watts
HI Darren
I forgot to tell you where I got my shocks from. I used the heaviest strength ones which are 400 newtons but the choice is yours. The part number I ordered from the website below was W06YBO0400
http://www.assocspring.co.uk/p/258/nitr ... lded-eyes/
I ordered 5 as the price break and postage worked out cheaper than ordering 3 if my memory serves me right and then you have spares or Glider ones
Ray
Re: 30% Wilga Build
Posted: 15 Feb 2016, 22:14
by Elliot Howells
Darren, she looks great!
Did you make your own pattern for the cowl? I plan to make a wooden one, there's always a need to for nose weight, so I'm happy with that, plus I'm not putting any servos in the tail, my last Bondy wiggler had 2lb or more of lead at the front of the cowl.
Ell.
Re: 30% Wilga Build
Posted: 16 Feb 2016, 21:52
by Darren M
Hi Ray
Thanks for the link thats them sorted.
Elliott
I made a blue foam plug and molded the cowl over that. I used the dimensions as drawn by Mike but I did add the flared section on the port and starboard side of the cowl.
Darren
Re: 30% Wilga Build
Posted: 20 Feb 2016, 11:47
by Elliot Howells
Thanks Darren,
as a side note, I want to use carbon pushrods for the elevator controls, I would use Pete Tindal's stuff, but I think they're no longer trading?
What are you using?
I\m mounting my rudder/ tail wheel servos in the forward fuzz too so will use pull/ pull and possibly a pushrod for the rudder, haven't quite decided.
Cheers, Ell.
Re: 30% Wilga Build
Posted: 17 Apr 2016, 22:20
by Darren M
Hi Elliot
I've got the rudder servo in the tail as per the drawing and I'm using a carbon push rod for the elevator the tail wheel is on a closed loop both servo's up front.
I'm underway with the final fit out so the project is finally drawing to a close.
Darren
Re: 30% Wilga Build
Posted: 18 Apr 2016, 08:55
Brian will be having apoplexy.......
Steady Brian, focus on the plane, and nothing else..
Re: 30% Wilga Build
Posted: 24 May 2016, 17:25
by Elliot Howells
Looking good Darren, I'm envious, I've got side tracked by life and work...
Did the vespa GTS 300 inspire your colour scheme ;)
http://pictures.topspeed.com/IMG/crop/2 ... 600x0w.jpg
Ell.
Re: 30% Wilga Build
Posted: 26 May 2016, 22:22
by Darren M
Well spotted Elliot looks a good match.
Thats me about done with the wilga and I would just like to thank Barry for doing a great job on the decals they finished it of nicely.
Darren
Re: 30% Wilga Build
Posted: 27 May 2016, 08:11
by john greenfield
Not got the silencer cans mounted yet then Darren ?
Re: 30% Wilga Build
Posted: 27 May 2016, 21:55
by Geoff Pearce
Do you blame the bees when you run the motor up?
Buzz.".....buzz,buzzzzzzzzzzzzzzzz :lol:
Looking good
Geoff
Re: 30% Wilga Build
Posted: 27 May 2016, 22:30
by Tonyh
That you at the back of the queue next week Geoff
T.
Re: 30% Wilga Build
Posted: 28 May 2016, 20:52
by Geoff Pearce
Tonyh wrote:That you at the back of the queue next week Geoff
T.
Oh good ,more time to eat all the cakes then!
G
Re: 30% Wilga Build
Posted: 30 May 2016, 08:31
by john greenfield
MarkDev wrote:Nice job Darren I shall be the one in front of Geoff! :lol:
For the cakes or a tow ???
Re: 30% Wilga Build
Posted: 30 May 2016, 13:32
by Geoff Pearce
It will probably be a cake per tow, that sorts out tug payment
G
Re: 30% Wilga Build
Posted: 11 Jun 2016, 11:04
by Elliot Howells
Did you make the legs yourself Darren?
She looks really good.
Ell.
Re: 30% Wilga Build
Posted: 11 Jun 2016, 20:40
by Darren M
Hi Elliott
I made the legs as per the drawing except for the aluminium fairing. I bonded foam on the aft edge of the aluminium leg then faired it in and covered them with 200g glass.
Darren
Re: 30% Wilga Build
Posted: 16 Jun 2016, 19:54
by Elliot Howells
I've been trying to make the milling vice work on my lathe to try and do this sort of thing, not having much success...
Getting the bottom of the legs at the correct angle needs a more muscular setup I'm sure, perhaps even an actual milling machine.
Have you seen Steve Davis' wilga? Pure craftsmanship.
Ell.
Re: 30% Wilga Build
Posted: 17 Jun 2016, 08:15
by john greenfield
Hi Elliot
I made the bottoms of the undercarriage legs for Darren's Wilga and yes they were made on a vertical milling machine after first turning the legs to size on a lathe. The trick is to make good jigs to hold the piece at the correct angles before machining.
Re: 30% Wilga Build
Posted: 22 Jun 2016, 23:00
by Elliot Howells
Thanks John,
maybe I'll outsource mine then, don't have room for a milling machine sadly, or a mate who owns one!
Thanks, Ell.
Re: 30% Wilga Build
Posted: 23 Jun 2016, 08:40
by john greenfield
Elliot Howells wrote:Thanks John,
Thanks, Ell.
Elliot
you should always have room for a mate who owns a milling machine !!!
Re: 30% Wilga Build
Posted: 17 Oct 2016, 20:20
by zordak
Have started building Bondies 30% Wilga and was wondering if anyone one this forum has a source for the bubbled clear doors and maybe premade cockpit install. Panel and seats!!
Regards Glenn from Australia.
