Teakle ASW 20 3.5/1
Martin Church
Re: Teakle ASW 20 3.5/1
Post by Martin Church »
Had a go at mounting the wings last night after drilling the incidence pins. Up to this point I hadn't truely realised how big this model is. Still need to couple the wing controls up to the servos & finalise the rx installation & it should be ready for its maiden.
Martin Church
Wing servo cover design taking shape on the 3d printer just building up the layers? Will be one piece eventually so you can screw servo to inside & bolt in place. Will also be printed in white not silver.
Martin Church
Well I’ve hit a brick wall trying to the hinge these ailerons & flaps. I should never had listened when I was told to cut off the living hinged surfaces ☹️
I’ve tried several times to re hinge them but they are bowed & buckled & whatever I do they just won’t sit on the back of the wing like they did when they were attached. I’ve looked at trying to get trailing edge stock but nobody does it over 3 foot long.
I’m at my wits end with it I’m no builder & to be honest it’s very nearly up for sale!
Martin Church
The hinge was too stiff Cliff after I’d glassed the wing I put up a post & was advised to cut the hinges off & tape them in place. I didn’t think they would have bowed & buckled as they did tho & how the gap has been routed out there is little to no gap to allow the surface to deflect how it needs to.
Martin Church
Maybe cliff, carving a new set of waggly bits is the only fix & straightening out the hinge line of the wing & fitting a false edge that’s the only way I can straighten it all out.
Martin, why not bring a wing along to the Scale Fly In on Sunday and let us take a butchers...? (Howzat for optimism?)
Martin Church
Will do Chris
Martin Church
Thinking of moving this on now if anyone is interested.
It’s well beyond my capabilities to finish it & has been replaced by an asw22 baudis & a let models ASH26E
Plus have a HH ASH31 on order.
Martin Church
Sorry Keith there’s a long que for my twenty two 😉
The ASW 20 is the only one I’m selling 👍
Andy Wallace
Post by Andy Wallace »
Martin I feel your pain
I'm into my second year of building my ASW20 I wonder sometimes if i've bitten off more than I can chew
I'm hoping to have it finished before September next year :D :D
